Lowering???
Moderator: Ian
Gasy
Re: Lowering???
Post by Gasy » Thu Sep 24, 2015 6:21 pm
That's a good price
Makes mine look dear
xt600
Re: Lowering???
Post by xt600 » Tue Oct 20, 2015 9:33 pm
Can recommend Springcoil, they made mine and fit perfectly. I went for 30mm drop and 25% uprated. These work well with my 17" wheels... the Bongo feels much more stable at speed and I can take corners better. Negotiating speed-bumps is fine too, I wouldn't go any lower than this though.
Puma931
Re: Lowering???
Post by Puma931 » Mon Oct 26, 2015 10:18 pm
Can you post a pic of you van, and confirm the distance from the top of the wheel arches to the ground. I need to decide what drop to go for. Thanks
xt600
Re: Lowering???
Post by xt600 » Tue Oct 27, 2015 10:38 am
I would, but not sure how to add images to my post on here?
wonkanoby
Re: Lowering???
Post by wonkanoby » Tue Oct 27, 2015 10:48 am
xt600
Re: Lowering???
Post by xt600 » Tue Oct 27, 2015 7:02 pm
Thanks, I have put the picture on Photobucket but it still doesn't appear on the post, just the URL address?
Gasy
Re: Lowering???
Post by Gasy » Tue Oct 27, 2015 7:16 pm
Copy all
Where it says image ..................
On the right hand side of photobucket
Then paste onto here
xt600
Re: Lowering???
Post by xt600 » Tue Oct 27, 2015 7:26 pm
Height to arches = 740mm/29" But bear in mind my wheel/tyre combination brings the van UP 10mm so with standard size wheels/tyres the measurement to arches will be 10mm less...
BongoJonny
Re: Lowering???
Post by BongoJonny » Thu Nov 05, 2015 5:08 pm
I can get hold of lowering springs from Japan but there not cheap expect to pay £200 for a set.
Return to “Pimp My Bongo”
