Waeco MS 50 Cruise Control - Fitting
Moderator: Ian
Bongold
Re: Waeco MS 50 Cruise Control - Fitting
Post by Bongold » Sun Jan 28, 2018 5:13 pm
Can someone provide the fitting instructions for the MS50 please? I have a V6
Thanks in advance! :D
Post by Bob » Sun Jan 28, 2018 5:57 pm
Try this:
https://manuall.co.uk/waeco-magicspeed- ... e-control/
And from memory Simon Jones did a Fact Sheet some while back.
Tough times don't last, tough people do. 8)
scanner
Post by scanner » Wed Feb 14, 2018 9:39 pm
Found this possible source for MS50s if anyone is still looking.
https://www.carandcamp.com/autozubehoer ... ms-50-ms50
Post by Bob » Wed Feb 14, 2018 10:18 pm
Jolly good find Scanner. =D>
I can highly recommend this unit for the Bongo. 8)
fatcatlawyer
Post by fatcatlawyer » Wed Sep 04, 2019 2:45 pm
Hi, I have fitted and wired up all except the two brown wires that get connected to the brake light circuit. Any hints as to
: where to find the best place to do the connecting and confirmation that the two brown wires with the lit can be interchangeable
Yours Ian G
Post by Bob » Wed Sep 04, 2019 3:23 pm
I connected to the switch fitted above the brake pedal.
I would have thought if the wires weren't interchangeable they would be different colours. [-o<
Edit: I seem to remember it being spade connectors so easy to use piggy backs.
