Project - Retrim and new paint
Moderator: Ian
Gasy
Re: Project - Retrim and new paint
Post by Gasy » Fri Jun 12, 2015 6:06 pm
Has the roof gone back to white ?
The green sides look cool
I'd like to do my roof and the sides around the windows in Matt black
Puma931
Post by Puma931 » Mon Jun 15, 2015 10:15 am
The roof is now the same colour as the main body (silver grey).
Gasy wrote:Has the roof gone back to white ?
TheStinkyHippy
Post by TheStinkyHippy » Mon Jun 15, 2015 12:02 pm
Did you replace the rubber around the roof in the end?
Mark Elvin
Post by Mark Elvin » Mon Jun 15, 2015 12:14 pm
What's the chin spoiler from?
meek.tv
Post by meek.tv » Mon Jun 15, 2015 12:52 pm
Are you going to the Stourport bash Puma931?
would be good to check it out properly, it's looking great
.......... cycling more.
Mark Elvin
Post by Mark Elvin » Mon Jun 15, 2015 1:01 pm
Mark Elvin wrote:What's the chin spoiler from?
Ah, a T4, just read back through.
What was is like to fit?
TheStinkyHippy
Post by TheStinkyHippy » Mon Jun 15, 2015 3:30 pm
Did you also use Rustoleum roller on the roof?
wonkanoby
Post by wonkanoby » Mon Jun 15, 2015 7:07 pm
can i ask were you bought the rustoleum
Puma931
Post by Puma931 » Tue Jun 16, 2015 11:35 am
I modified one of these
http://www.ebay.co.uk/itm/VW-T4-TRANSPO ... 1c486c0d86
Puma931
Post by Puma931 » Tue Jun 16, 2015 11:39 am
TheStinkyHippy wrote:Did you replace the rubber around the roof in the end?
Yes, I ordered 8m and fitted it, but got stuck at the back as it was too tight to fit and not enough space to hit with a mallet, so I did not bother with the final part above the tailgate.
http://www.woolies-trim.co.uk/p-1606-fl ... -seal.aspx
Puma931
Post by Puma931 » Tue Jun 16, 2015 11:40 am
wonkanoby wrote:can i ask were you bought the rustoleum
Paint: Rustoleum Combi Colour which was applied with a 4 inch roller brush.
Web link regarding roller painting process tips etc - http://forum.club8090.co.uk/viewtopic.p ... start=2655
I bought the paint from: https://www.promain.co.uk/product/rusto ... oss-id1190 and 2.5 litres should be enough to do a van (same colour) or 5 ltrs if a colour change. Thin down with white spirit (4 parts pain and 1 part thinners)
Best roller brush to use: 4 inch mohair roller. I tried foam rollers but got loads of air bubbles when painting http://www.ebay.co.uk/itm/321539611467? ... EBIDX%3AIT
Pain trays: Wickes sell cheap clear plastic trays (5) for about £2.50
I sprayed the green bits with plasticoat paint from Hobbycraft as other aerosol paint reacts with Rustoleum.
Puma931
Post by Puma931 » Tue Jun 16, 2015 11:41 am
TheStinkyHippy wrote:Did you also use Rustoleum roller on the roof?
Yes :-)
Mark Elvin
Post by Mark Elvin » Tue Jun 16, 2015 12:49 pm
Did you try loosening off the AFT nuts that hold the brackets to the roof, allows you to lift the rear edge slightly.
Puma931
Post by Puma931 » Tue Jun 16, 2015 2:39 pm
No #-o
bongoroy63
Post by bongoroy63 » Tue Jun 16, 2015 7:01 pm
A few questions regarding your purchase of the roof rubber seal:
1/ was 8mts the right length to buy?
2/ is this a like for like replacement or is it different in any way?
3/ is it not possible to undo the bolts on the back of the roof and lift it a bit to fit it on?
4/ is it a good fit?
5/ what was the length of delivery?
My Bongo has just gone in for a respray and the rubber is looking shabby and cracking in places. I want to replace mine to finish it off.
I can, I do, I did.
Return to “Pimp My Bongo”
