Project - Retrim and new paint
Moderator: Ian
Puma931
Re: Project - Retrim and new paint
Post by Puma931 » Mon Apr 13, 2015 5:38 pm
I have not fitted it yet as I am painting to roof so need to wait until the oil based paint hardens.
I will post a pic next month.
TheStinkyHippy wrote:How was the replacement seal for roof?
Puma931
Post by Puma931 » Mon Apr 13, 2015 5:43 pm
Front end has had it's 4 coats! Just need to wait a few weeks until it is rubbed down with 1500, 2000 and 2,500 and then polished.
The rest of the van is taking time as painting outside is not easy (bugs, wind/dirt etc) so I need to find a garage to do the final coats.
VW bib spoiler fitted (middle section) the outer parts need to be cut and bonded to the bumper with tiger seal (PU adhesive).
I also need to make the underside cooling vents larger as the bib spoiler blocks them.
I hope to have it all finished by the end of May :-)
Gasy
Post by Gasy » Mon Apr 13, 2015 7:00 pm
Is this any good for a new roof seal £3:50 per meter
Eblay 131061093518
the.sasquatch
Post by the.sasquatch » Mon Apr 13, 2015 9:15 pm
looking cracking so far, can't wait to see it finished
Puma931
Post by Puma931 » Tue Apr 14, 2015 8:39 am
No, you need a rubber tube on the edge to form a seal.
Gasy wrote:Is this any good for a new roof seal £3:50 per meter
Eblay 131061093518
Puma931
Post by Puma931 » Wed Apr 15, 2015 8:20 am
sprayed a bit of matt black on the bumper and fitted my 2nd hand fog lights. :idea: Just need to add a red pin stripe now.
Puma931
Post by Puma931 » Wed Apr 15, 2015 11:38 am
This is the one I went for:
http://www.woolies-trim.co.uk/p-1606-fl ... -seal.aspx
Puma931 wrote:No, you need a rubber tube on the edge to form a seal.
Eblay 131061093518
Puma931
Post by Puma931 » Mon Apr 20, 2015 2:55 pm
Almost finished my rear cupboard above the cooker/sink unit :-)
Also cooked my first bacon cobb (I was in Derbyshire)
meek.tv
Post by meek.tv » Wed Apr 22, 2015 4:08 pm
loving this colour, can't wait to see it finished
.......... cycling more.
Puma931
Post by Puma931 » Thu Apr 23, 2015 4:51 pm
As it is so difficult to roller paint around/behind the side windows, I have decided to rattle can some red which will follow the lines of the van, from the line below the mirror, to the small curve at the top of the front wing, up and along the gutter and down the line on the rear side window back to the line that runs along to the front mirror. The bonnet will also have some red again following the lines in the panel, plus the mirrors will also be painted red. There are some nice lines on the van to follow so hopefully it will look good.
Below is a guide of what it could look like...
meek.tv wrote:loving this colour, can't wait to see it finished
Puma931
Post by Puma931 » Mon May 11, 2015 9:22 am
small update...
Fitted BMW electric window switch to the n/s and need to work on the o/s now.
VW splitter has been fitted and secure in place with ss screws and ss bolts. The front now looks good with the red pin stripe.
I'm on the final rub down before the final coat of rustoleum :-) trying to get rid of the orange peal takes time!
Rattle canned the mirror red and the rest will be done once the final coat of rustoleum is done.
Post by mikeonb4c » Mon May 11, 2015 9:41 am
Looking good - I'm starting to get excited at seeing the finished product :-)
Puma931
Post by Puma931 » Fri May 15, 2015 10:21 am
Final coat of rustoleum paint to be applied with a roller tomorrow :D using my mates garage so less chance of bugs and dust :D :D
I am also converting the other rear side window to house a 19 inch TV that will flip out, so it can be watched from my reversed middle seats :idea:
Should all be ready for a bank holiday trip to Devon later this month :D :D :D :D :D :D
Puma931 wrote:Image
thevanarchist
Post by thevanarchist » Fri May 15, 2015 10:22 am
Ditto :D (for seeing the finished Bongo that is)
Post by mikeonb4c » Fri May 15, 2015 12:31 pm
Puma931 wrote:Final coat of rustoleum paint to be applied with a roller tomorrow :D using my mates garage so less chance of bugs and dust :D :D
Puma931 wrote:Image
Make sure all the paint fumes have gone before you start kipping in it!!!
Return to “Pimp My Bongo”
