Has anyone changed the front seats ... And what you exchange the for?
Terri x
Front seats
Moderator: Ian
Re: Front seats
Re: Front seats
Ditto - they came from an accessory shop in Gt Yarmouth and we had to get adaptor plates made to mount them on the standard runners.
You need seats with a very thin base or your head will be so high you can't see through the windscreen.
- Simon Jones
Re: Front seats
Bear in mind that if you use the seats to make up part of the bed, then funky curvy ones won't really work. Also make sure you can still access the engine compartment as it would be a major pain if you had to unbolt them just to check oil.
