Page 3 of 3
Re: Reverse light bulb
Posted: Mon Mar 05, 2018 6:30 pm
by Bob
Sounds ok to me, hopefully Geoff will confirm.
Posted: Mon Mar 05, 2018 8:04 pm
Umm not quite sure what is being used here, but any standard lamp to be used on a car is never going to exceed 55 Watts (Main beam headlight) legally, which means it draws 55/12= 4.6 Amps Max. a 10 Amp wire will be more than adequate, but do make sure its automotive grade insulation which is harder and more resilient than insulation used for other purposes where there isn't vibration etc. Most joints these days would be done using crimp joints but soldering is adequate as well.
Posted: Mon Mar 05, 2018 8:21 pm
by Dungoisdadsbongo
Thanks for your response Geoff, the light is below;
https://rover.ebay.com/rover/0/0/0?mpre ... 2756529484
So it's ok in this instance to use greater ampage wires when joining and what would you expect the reverse light wire ampage to be?
Posted: Mon Mar 05, 2018 8:55 pm
by TheLongRoad
Very similar to what I fitted as a reversing light on my 4x4. I used solder joint with heat shrink. The cables are automotive type of a similar guage to the existing reversing light, Being LED these don't draw a lot of current. Hope this helps.
Posted: Tue Mar 06, 2018 12:16 am
OK well they are each rated at 12 Watts so each lamp draws 1 Amp each so 2 Amps for the two together, and yes its fine to use a cable rated for a higher current - its actually preferable to do so! I would still stick with something rated at about 10 Amps like this
http://www.vehicle-wiring-products.eu/p ... -sq-16-020
Posted: Tue Mar 06, 2018 7:39 am
by Dungoisdadsbongo
Thanks for spoon feeding me on this guys, I'm completely new to all this, I'm loving having a bongo and don't want to have the maintenance and adjustments to beat me!
Kind regards
Posted: Tue Mar 06, 2018 1:50 pm
by TheLongRoad
We all start as novices. Just keep asking and reading and you’ll get to know your Bongo.
Posted: Tue Mar 06, 2018 2:12 pm
by Bob
Very true, and many others learn from questions asked and answered on here, even if they choose not to post.
