I was told that the situation in Germany has changed, as it has recently here in Portugal and for german registration and BFG they now must have proper LHD dip patterns, only UK registered can flatten. Also I can now report my lights are now 10 times better at night than before, so there are good reasons for making the change.helen&tony wrote:Hi Maxi..
As I stated above...Germany have been quite happy with a straight dipping when re-registering...and as I said, everywhere is different. In some testing stations here they are fussy about the headlamp lens itself regarding prismatic patterns...others...none too fussy....,
Did you have any trouble with your VIN plate, by the way...???...as it's a sticker on the Bongo, they weren't going to accept it here....but given the body number stamped under the windscreen, they finally accepted it....
No problems with the VIN plate though the VIN number doesn't work in the system here not enough numbers.
