Rear Gate for bongo friendee in finland?
For all owners and afficionados of Mazda Bongo Friendees and Ford Fredas based outside of UK or Ireland.
Moderators: helen&tony, Ian
Suoppo
Post by Suoppo » Wed May 20, 2015 8:45 am
Hello,
Im looking for a rear gate for bongo friendee with free top, with shipping to finland.
I live in finland, and i have the only bongo here, so no spares available.
If someone has a rear gate to offer or if someone could help, please contact.
I'm also looking for the whole Cardan Shaft, it is a bit twisted.
Thank you!
Kindly,
Sampo Saukko
Re: Rear Gate for bongo friendee in finland?
Post by g8dhe » Wed May 20, 2015 9:15 am
Give George at Bongospares a call he will ship anything anywhere I do believe http://www.bongospares.co.uk/
Simon Jones
Post by Simon Jones » Wed May 20, 2015 5:45 pm
Be aware there are 3 types depending on age & spec so best to send a photo to the supplier to confirm it's the same type.
teenmal
Post by teenmal » Wed May 20, 2015 6:09 pm
You will also need to let them know whether its 2WD or 4WD.
Simon Jones
Post by Simon Jones » Wed May 20, 2015 7:24 pm
Just to clarify, I was referring to the tailgate :).
Post by Northern Bongolow » Wed May 20, 2015 8:03 pm
im still wondering what shaft he needs.
dobby
Post by dobby » Wed May 20, 2015 10:05 pm
Cardan shaft is a drive shaft http://en.m.wikipedia.org/wiki/Cardan_shaft
I didn't actually know that but googled it.....
Suoppo
Post by Suoppo » Mon May 25, 2015 11:22 am
Thank you for fast reply! :)
I have been in contact with George earlier.
The price of the shipping was quite high then, but it is one option.
I was just looking for a better price.
By Cardan Shaft, i mean the whole shaft from transmission to back which spins the rear wheels.
Also the "ball joint/universal joint?" if im saying this right, is a bit damaged. I think those i can get pretty cheap as new too.
I do not know how to explain this properly in english...
Thanks,
Sampo Saukko
Post by Northern Bongolow » Mon May 25, 2015 3:38 pm
is it 2 wheel drive or 4 wdrive, the prop shafts are different lengths.
4wdrive.
http://lushprojects.com/bongopartsmk2/c ... mgno=.html.
2wdrive.
you say it is twisted, so is it the rear drive/half shaft.
parts drawings are here.
scanner
Post by scanner » Mon May 25, 2015 5:09 pm
Is the tailgate damaged?
If so how badly? As it may be that repair will cost less than replacement.
helen&tony
Post by helen&tony » Tue May 26, 2015 7:34 am
Have you tried Norsk European Wholesale for transport of parts? : http://www.norsk-global.com/ They are a reasonable price and pretty quick. You get the part to their depot in the UK, and they get it to your local company in Finland. I just had a part picked up by Parcel Monkey in the UK, and shipped here by Norsk....surprisingly quick! I think TNT are good to your region...sometimes I've had bits from Riga within a day or two!
Suoppo
Post by Suoppo » Tue May 26, 2015 9:32 am
Thanks again!
It's 4WD
I will check the Norsk thing!
Tailgate is damaged, and the window too.
If i could get only the window for cheap, it would be smart to fix the tailgate.
It's just that the gate itself does not cost that much, it's the shipping. Which is almost as expensive for the window only, because its glass.
Maybe this Norsk European shipping thing helps!
We are still exploring the problem with the cardan shaft, it can be that the universal joint is not installed properly. Anyway, it is out of balance, and the car is vibrating bad in highway speeds.
We'll see..
Thank you,
Sampo
helen&tony
Post by helen&tony » Tue May 26, 2015 11:40 am
Norsk might be good to contact...they are agents for TNT, and I know TNT are good in Latvia, and I'll bet they deliver to Tallinn, then it's a ferry "hop" to Helsinki!
Good Luck
Return to “International”
