ROOF Stuck Down !!!
ROOF Stuck Down !!!
Hi. Reverse Problem to the Usual, Engine Running, in Park, Handbrake ON,Push Button to raise roof,Light on dash flash's,bleeps front and back but the roof doesn't budge,can't hear Motors, any idea's ?
Or how can I raise the roof manually to get at the Motors ?
Thanks in Advance.....
- dandywarhol
- dandywarhol
Not the point kozikot - the items were never in the post, you thought they went too cheap and sent the money back! As for the ladder - no idea what you're on about, I wouldn't deal with you after the first shafting, maybe some other mug got "mugged"........maybe a concience problem there kozikozikot wrote:dandywarhol you were refunded in Full ! and the Ladder was returned to us on 18:12:06, so one should not jump to conclusions as early as your keen to ! Anyway now Sorted.....The Dog may be next to you !
Anyway - glad you got the roof sorted - Goodwill to All etc...
Stuck Roof
So please share your knowledge with us all Kozicot just in case we are in the same predicament. How did you raise the roof to get at the motors?
Kozicot -
The ladder which never arrived was the one I bought from you and I believe that it was never sent because you were unable to provide any proof to me that it had been sent off .
You pulled the same trick on Dandy over another item and you have been caught out. Make a New Year's resolution to be a nicer person.
