Hi All,
Anyone who has fitted a front wheel bearing have any experience that might help me with the job?
And will I need a press?
Thanks in Advance.
Fitting a front wheel bearing- will I need a press?
Re: Fitting a front wheel bearing- will I need a press?
I can confirm that as well. I had the issue a couple of months back when they made the switch from the two-piece to the one-piece. Took calling customer service 4 times before they got me the correct instructions. As previously stated insert the bolts from the opposite side of the wheel into the bearing housing.
