Sliding door closer
Sliding door closer
My sliding door closer has stopped working , the fuse is ok ,the electrical connection are good and the contacts are clean , my van is a 2003 2 L petrol hard top any Ideas please
- g8dhe
Re: Sliding door closer
It maybe the motor inside the door there is an item here, but the images are missing but I have saved them on the link below;
https://www.igmaynard.co.uk/bongo/forum ... 99#p696899
images here
http://www.g8dhe.net/bongo_images/Slidi ... placement/
images here
I have 5 volts at the door pillar , I assume this is correct
- g8dhe
Well some of the pins sensing the switch positions etc will have 5 volts, yes. But the door motor pins will have a full 12 volts on them when they are powered.
