Passenger side door latch
turfite9999
Post by turfite9999 » Tue Jan 05, 2021 5:24 pm
Hi bongonoughts
Can anyone tell me how to remove and replace door latch, I cant seem to be able to shut door, maybe its twisted or jammed.
I have removed inner trim but cant get passed the steel panel for all the workings i.e. window mechanism, lock handle.
Hope someone can help, many thanks in advance
Tony, [email protected]
Re: Passenger side door latch
Post by g8dhe » Tue Jan 05, 2021 5:41 pm
Do you mean the sliding door or passenger door ?
Have you tried the mechanical parts drawing site for more info ? http://www.lushprojects.com/bongopartsmk2/
Image Spherical Visions
turfite9999
Post by turfite9999 » Tue Jan 05, 2021 5:45 pm
Hi Ian sent me plans (thank you Ian) but cant get to them unless inner STEEL panels can be removed
Regards
Tony
turfite9999
Post by turfite9999 » Tue Jan 05, 2021 5:46 pm
Sorry passenger door
Post by Bob » Wed Jan 06, 2021 3:59 pm
This video might help, just ignore the first bit about the tailgate.
https://www.youtube.com/watch?v=al91xf0hLuE
Looking at it I recon you should be able to remove the latch once the panel is off and you remove the screws holding it from the door edge. :wink:
turfite9999
Post by turfite9999 » Fri Jan 08, 2021 5:32 pm
Thanks Bob and others for help so far will attempt something when weather a little better
Tony
turfite9999
Post by turfite9999 » Mon Jan 11, 2021 2:17 pm
Hi again guys, trying again to replace or fix front passenger door latch, do you think I`ll have to cut out the steel panel to replace? finding it hard to get to after removing door trim.
Thank you in advance
Tony
Post by g8dhe » Mon Jan 11, 2021 2:48 pm
Which bit are you trying to gain access to ?
The loop - striker on the "B" pillar 58-570A ?
The motor / lock within the door 58-340 ?
turfite9999
Post by turfite9999 » Fri Jan 15, 2021 11:48 am
Hi Geoff thanks for your question, it1s the latch 58-302 I think which locks onto 58-570
regards
Tony
Post by g8dhe » Fri Jan 15, 2021 12:23 pm
58-302 is the screw that holds the locking mechanism in place, if you unscrew that then the motor and lock itself will come out of the door once you have released the wire links to the handle and locking button full details of the mechanism here http://www.lushprojects.com/bongopartsm ... no=.html#5 which holds all the mechanical/parts diagrams .
turfite9999
Post by turfite9999 » Fri Jan 15, 2021 4:18 pm
thanks geoff I will try that
Tony
turfite9999
Post by turfite9999 » Sun Jan 31, 2021 11:44 am
Hi bongonoughts
I know it`s not a usual problem but has anyone ever changed the latch/locking mechanism on passenger side door please.
If so please could you advise how to do it or to access it?
Many thanks in advance
Tony
turfite9999
Post by turfite9999 » Wed Feb 03, 2021 8:40 am
hi guys sliding door started doing same, I have lost my fuse box diagram please could someone send me a link.
Under bonnet and in cab
Tony
Post by g8dhe » Wed Feb 03, 2021 9:57 am
All the fuses and lights are listed with function and replacement source here http://www.g8dhe.net/bwm
Have you managed to get into the passenger door lock yet ?
turfite9999
Post by turfite9999 » Thu Feb 04, 2021 11:28 am
Hi Geoff,
thanks for the reply regarding fuses and the link,
The central locking seems to be working and I think I can get the latch out, I`m a little afraid of taking it out completely due to restricted accesses. I think it could be the arm that connects to the latch or the motor that operates the latch, (chicken and egg) The latch seems to be stuck so the doors wont close, just bangs against the catch bar (if you know what I mean) I may have to replace the whole mechanisms, if i can do it with limited knowledge, anyway thanks for your help so far
Tony
