Hi all,
Just after any pointers or tips before I replace my exhaust.
I have the standard bongo (no cold start) so it will just be the usual 3 piece kit.
Replacing Exhaust
- Apprentice Bongonaut
Re: Replacing Exhaust
One of the nicer jobs to do on a bongo as you can nod off while your underneath and the wife thinks your busy at it.
Get the gaskets and spare nuts and bolts and you should be fine.
Check that the mounting plate on the gearbox is present as some remove it.
