Galley / kitchen wiring
really need an english wiring diagram for the original kitchen - have a wire from the loom not water pump - has white and blue stripe green with red stripe and green with white stripe - this has been disconnected from something - anyone know what it is and where it goes ?
- g8dhe
Re: Galley / kitchen wiring
Diagrams here, with the necessary translations to identify bits A Blue/Red wire is used for the water pump;
The charging and switching circuits are here;
If you really want to see other translations then use Google translate facilities / images, but generally the extra info is rarely that helpful!
Blue with White stripe is used for the pillar light.
White with Green stripe is the +12 v power to the switches.
Green with Red is part of the power switching circuits.
thankyou ! yes just downloaded translate !
Hello,
We just purchased a 1996 Bongo in the US. There were several "interesting" modifications to the factory installed kitchen and I am trying to make sense of the mess of wires. Does anyone know if these wiring diagrams have been reproduced without flash and where I can find them?
Thanks!
Thanks!
- g8dhe
No the only other route is buy the scanned images from the shop. However that will only show you the original not the modified version!
I have reviewed the wiring diagrams available to the members and it looks like those diagrams are just for the base vehicle, not the factory kitchen add on. I’d like to understand the original factory wiring for the kitchen so that I can remove what’s not supposed to be there and restore it to the factory configuration. Does anyone know where to point me towards this information?
Thanks!
Thanks!
- g8dhe
The diagrams I have posted above are for the Corner Galley system as its called in the diagrams, they are of the optional module and don't form part of the base vehicle at all.
