Diesel Heater Fitting Question
Hi All
Not the normal question but would be interested to hear others experience.
I am in the process of fitting a Diesel heater under the passenger seat as most seem to, I will be routing the hot air into the rear door step area and probably taking the cool air feed from the passenger footwell area. All pretty standard.
Question is to anyone that's done it this way. Has it increased engine noise into the cab when driving effectively as it effectively has 2 60mm holes open to the engine bay with only some thin ducting between?
I am trying to reduce noise where I can not make it worse. If it does any ideas how to reduce the impact.
Re: Diesel Heater Fitting Question
Interesting question and not one i've heard raised before (though noise in operation gets discussed). Maybe you could design removable blanking covers?
As a matter of interest have you got your insurer’s approval , if so what if any was the increase in policy.
Good point on insurance.
I haven't actually checked. Will keep you posted.
Mikeonb4c
yes that may be an option. wouldn't ever use it while driving
Mikeonb4c
Just checked with my insurance.
No issues at all and no change to premium.
You might even flog a few if you crack the design (assuming there is a problem that needs cracking mind you!)
No increase in noise from the engine noted, we ran one for 5 years on ours.
Best thing you will ever buy, we fit ours like you which heated the awning too when you fit a swivel eyeball vent.
Toasty.
Toasty.
Whilst it’s only a short ducting run I would probably add a small amount of insulation. Mine ran to center console back so was a little bit longer But. did marginally improve noise both in operation (didn’t really notice whole driving). My ducting run needed some heat shielding on top of the insulation, first time round the insulation melted as it was touching the exhaust manifold to exhaust connection!
Thanks guys
Probably am over thinking it. But fitting some insulation around the ducting sounds like a good idea.
Looking forward to getting it going, hopping it will mean I use the van a lot more.
One more question. Did you both T into the van fuel supply without any issue I was planning on going into the fuel return. Have read mixed views on this as well.
WestyK wrote: ↑Tue Mar 10, 2020 12:32 am Thanks guys
Interesting point,do you actually think the fuel return will be live without the engine running ?
From what I remember I used supply rather than return roughly under drivers seat, it just needs to be before fuel pump, mine is a 97 bongo just for reference. I don’t think there is any problem doing this and I’ve run engine and heater without issue. This is all from memory though I could go check tonight if it helps and take a few pics
I thought the same about the return to be honest but other have done it no issues and my thought were if it works its less likely to pull fuel out of the engine pump.
I am going to test without cutting any of the existing pipes so it can go back if it doesn't
If it doesn't I'll go in to the supply.
Don't go to a lot of trouble but of you can send some pic that would be great.
WestyK wrote: ↑Tue Mar 10, 2020 9:49 am I thought the same about the return to be honest but other have done it no issues and my thought were if it works its less likely to pull fuel out of the engine pump.
The fuel system has only one internal suction pipe,the return pipe does not have the ability to draw fuel from the tank,you could fit an internal suction on the sender unit.
Thanks Rita
This was my thought too.
unfortunately fitting an extra tank take off is quite difficult.
Will keep you all posted
If you are going to take off from the tank I went through the sender unit plate.you can remove from the van and do it on the bench. Dont forget to set the pipe to leave some fuel in the tank.
I may have a pic somewhere.
