Fuel pump leak - changing out the seals
- Bongonaut
Re: Fuel pump leak - changing out the seals
I didn't remove the advance piston, or the springs behind the housing, just the bell housing with the shims and the o-ring. I'm fairly sure I put it back together as it came apart, but I'll take it apart again this week and report back.
I'm wondering if there might be another reason for the problem. Anyone know what else might cause acceleration to be lacking at high load? Does it sound like a fuel problem? To me it sounds like a vacuum system or air intake issue ...
MyBongoiscalledDave wrote: ↑Mon Feb 24, 2020 3:09 pm I didn't remove the advance piston, or the springs behind the housing, just the bell housing with the shims and the o-ring. I'm fairly sure I put it back together as it came apart, but I'll take it apart again this week and report back.
Its possible that some dirt has entered the pump, or the filters are needing replaced / cleaned.
this is where you could get the 2x green seals https://bongoland.co.uk/product/diesel- ... -set-of-2/
- Bongonaut
I've been thinking outside the box a little on this. After I changed the seals, I noticed the rev range was down and not revving over 4000rpm. But I do remember that when I drive it back from buying it a couple of months back is was very underpowered and didn't like revving high at all. I do have a flashing hold light as well. I wonder whether the Throttle Position sensor is out of whack and thinks 4000rpm is actually 6000rpm and is redlining?
I'm going to check the voltages with a multimeter today in the ECU. If they're out, I'll do the flashing bulb diagnostic in the OBD port. What are people using for a bulb? Links to suitable bulbs please.
- g8dhe
Any small low wattage 12 volt bulb is OK, a dashboard illumination light is fine, pea bulbs for model train tracks etc.
- Bongonaut
Perfect, thanks for the heads up. How do you make the terminals of the bulb long enough to stretch from port to port? Solder and wire?
- g8dhe
Yup that's what I do.
- Bongonaut
Cool. So shall I.
Just in case anyone wants to buy a ready made bulb with long wire ends, here is a link;
https://www.rapidonline.com/wire-ended-filament-lamps
Just out of interest, is there a positive and negative (live and neutral) on the bulb that you have to insert the correct way around I to the OBD?
- g8dhe
Filament lamps are not directional, LED's are however which is why I suggest filament lamps saves problems!
Bear in mind that that the later ECU's flash the Glowplug light itself with the code, once the link is set, its only the earlier versions that need the lamp fitting to read the code.
- Bongonaut
Okay, thanks for the heads up again. I'll try to get a filament bulb. Mine is a 96 2.5tdi. I checked the light on the dash, but is a steady, repeating flash, so unfortunately I'll have to go the old fashioned way.
- Bongonaut
In the spirit of posting up successful fixes, I can say that I've fixed the problem with the flat spot at 4000rpm.
After messing around double checking all the work with the seal change, double checking all hoses were attached correctly, double checking the vacuum system and fuel system and cracking the injectors, I found out that the banjo strainer in the FIP was a bit dirty. I cleaned it with cotton buds dipped in diesel and replaced it (be careful not to drop it) and now it runs perfectly again.
Apart from the gearbox problems
Happy Thursday to you all.
Adam
Adam
Useful info, thanks, and well done.
If the Diesel suffers from lack of power or speed deterioration the first thing to do is change/clean all the filters .rita wrote: ↑Mon Feb 24, 2020 9:30 pmMyBongoiscalledDave wrote: ↑Mon Feb 24, 2020 3:09 pm I didn't remove the advance piston, or the springs behind the housing, just the bell housing with the shims and the o-ring. I'm fairly sure I put it back together as it came apart, but I'll take it apart again this week and report back.
