underbonnet fuse box
- turfite9999
- Bongonaut
- g8dhe
Re: underbonnet fuse box
The missing blade has the terminal wire attached to it, until you lift the box out and turn it over to see what has happened its difficult to suggest what happened or how to repair it.
- turfite9999
- Bongonaut
Thank you for that Geoff
Don't want to teach egg sucking, but disconnect the battery first.
- turfite9999
- Bongonaut
no thank you I would have forgot lol
- turfite9999
- Bongonaut
dont think this is the right forum but someone snipped wires and unbolted spotlights and nicked them does anyone know if there's a like security bolt?
- g8dhe
Security bolt for what ? The fuse box is just held in by nuts/bolts.
- turfite9999
- Bongonaut
no sorry my fault was on about something else someone nicked my spotlights sorry
I'd just use two nuts and lock together with a spanner, if you use a Nylock as one of them it will make it more difficult/time consuming so hopefuly the scum will move on.
- turfite9999
- Bongonaut
thanks for advice Bob
