ABS light on
- Alacrity
- Tribal Elder
ABS light on
My Bongo has been stood for most of this year with moving or being started as all. I need to use it this weekend but for various reasons I was only able to start it yesterday & the ABS light is permanently on from the moment it is switched before it is moved. There appears no issues with the wiring to the 4 wheel sensors, all have been disconnected, check & re connected with electrical cleaner used. Battery was disconnected for 10mins but nothing has changed. Battery has never gone flat as it is trickle charged by a solar panel.
Does anyone a) have any thoughts & b) know how to get the fault codes out & what they mean?
Bit worried as it needs an MOT before I go!
TIA Geoff
TIA Geoff
Re: ABS light on
Is it a pre-99 Bongo? Is there a diagnostic box in the passenger footwell?
- g8dhe
Re: ABS light on
To get the error codes see this link the ABS codes are at the bottom, last table http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
- Alacrity
- Tribal Elder
Re: ABS light on
Brilliant, many thanks. What is the method of clearing down codes for ABS?
- Alacrity
- Tribal Elder
Re: ABS light on
Plot thickens, I have code 55 - not on the list
- Tribal Elder
Re: ABS light on
Alternator had gone on ours when ABS light came on.. Check that battery is charging when engine running.
Re: ABS light on
It would be worthwhile giving the vehicle a run, applying the brakes regularly ( jabbing ).
- g8dhe
Re: ABS light on
I think you will find that on Ignition on it self tests, and displays any error until switched off again.
- Alacrity
- Tribal Elder
Re: ABS light on
Sorry chaps, bum steer there, I went & read it myself & got code 11 - right front wheel sensor. So a few tests tomorrow - hopefully just a sensor which is simple to sort out.
It has been driven for 10 miles but the light is on as soon as you start so it has to be electrical somewhere.
- Alacrity
- Tribal Elder
Re: ABS light on
Thanks for the help, (bloody expensive) wheel sensor sorted it.
