Nearside electric window problem...
- barney_the_bongo
- Apprentice Bongonaut
I have a problem with the nearside electric window: It will go down but not up when using the switch in the passenger side door. It won't do anything with the switch in the driver's door. I've studied the wiring diagrams and read everything I can on the forum but can't work out what is going on. Any advice would be very welcome!
Re: Nearside electric window problem...
Hi.
A common electrical fault is where the loom passes from the A pillar into the door, usualy the driver's side.
If you strip off some of the insulation often you can see breaks in the wires and/or insulation.
Easy enough to solder in a short extra piece, or new looms are available, but not cheap.
Good luck.
Good luck.
- barney_the_bongo
Thanks for your help Bob. Any idea which wire colour(s) to look for in 1999 2.5 Petrol Bongo.Bob wrote: ↑Mon Jun 24, 2019 9:30 pm Hi.
Good luck.
Jon
Can't remember, sorry.
But just look for signs of damage and join up the same colours where you find damage.
Central locking often fails, too.
- barney_the_bongo
Yes, I had problems with the central locking a while ago and found that it was a break in the yellow wire.
- g8dhe
Once one wire has broken then the others will shortly follow, much better to cut out the section and replace all with new lengths, Karl Chadwick does a kit with every thing you need including crimp tool. See here http://bit.ly/2RFG7ik you may need to ask if the kit isn't shown as they are in high demand!
Just a quick question, how do you get to the wiring? My passenger window only goes down from the drivers door switch and the electric mirror on the passenger side doesn’t work so my husband wanted to have a look at what was going on but he doesn’t know how to get to the wires. Thanks
Sharp Stanley knife or similar then gently cut the outer insulation away.
Careful not to cut the inner bits, but once you have a start you can pull it away as you cut.
Welcome aboard.
Welcome aboard.
Thanks, I was hoping there was a panel that would just pop off. I didn’t realise it would be so brutal. I only bought my bongo on Friday.
You can purchase a complete plugin loom from your local corner shop, check for vehicle date.
https://bongoland.co.uk/product/wiring-harness/
- barney_the_bongo
Hibarney_the_bongo wrote: ↑Mon Jun 24, 2019 9:17 pm Hi,
I have exactly the same problem with my nearside window. I've done everything I can to troubleshoot the issue (checked the wiring looms in the driver and passenger door, checked the switches, checked the motor and mechanism...)
How did you resolve your problem?
Jon
- g8dhe
When you say you have checked the looms and the switches was this with a meter? The wires in the loom break within the insulation quite often due to work hardening so a visual inspection doesn't always show any problems.
- barney_the_bongo
I must admit that I only vsually checked the wires. Just got a multimeter a couple of days ago and so far properly checked the switches and the orange wire which I thought would be the problem looking at the wiring diagrams (these were ok). I guess it will come down to striping insulation off all the wires one by one to test :/
Thanks.
Thanks.
Sometimes by manipulating the wires you can feel the ones with a broken core and the insulation may crack at the break.
