Flashing glow plug light after hill climb
Moonlight
Post by Moonlight » Sun Jun 02, 2019 5:42 pm
2.5 diesel, 2000. Recently had engine reconditioned and new head. Been feeling rather weak on hill climbs since work was done (1000km ago) then yesterday got to top of a slow incline and glow plug light started flashing. Any idea what’s going on?
Didn’t overheat, coolant level all good, no obvious sign of a problem. AA disconnected battery to reset and that “fixed” the warning light. Drove home okay but still lacking the oomph it used to have.
jimmo62
Re: Flashing glow plug light after hill climb
Post by jimmo62 » Sun Jun 02, 2019 10:11 pm
Sounds like in "fixing" the problem the AA have erased the fault code which would have given a clue about possible problem causes.
Suggest you search on here for how to read fault codes and when it happens again try to get the code - armed with that there will be plenty of people who can help on this forum....
Moonlight
Post by Moonlight » Sun Jun 09, 2019 10:24 pm
Ah dammit! Hadn’t thought of that. Would a garage be able to run a diagnostic check on it instead of me having to let it happen again?
Post by mikeonb4c » Mon Jun 10, 2019 10:41 am
Variable vane turbo on a 2000 model possibly? Could be sooted up and vanes sticking if so? Think i read some spraying oven cleaner into turbo as quick fix but best google for advice on wisdom of that!
Post by rita » Mon Jun 10, 2019 12:09 pm
It would be worthwhile checking / replacing all the filters,also have a look at the fuel cap breather valve.Have you contacted the people that reconed the engine ?...?
davben23
Post by davben23 » Mon Sep 23, 2019 10:50 pm
Was wondering if you found a solution to this problem after hill climb etc ?
Regards
