"Pinking" on my 2.0lt petrol bongo
Roy748
Post by Roy748 » Mon Apr 15, 2019 1:55 pm
Hi all
Just wondering if any other owners are experiencing the same engine pinking sound at 1500 rpm. I think it's called pinking, it only happens at low revs and when under load, or mainly when the engine is cold. I have tried filling at different fuel stations and some seem to help. Any ideas as to what it is and how it could be resolved.
Thanks in advance
Flanners
Re: "Pinking" on my 2.0lt petrol bongo
Post by Flanners » Mon Apr 15, 2019 4:45 pm
Plugs new-ish and correct? are you using supermarket petrol (I've stopped using it)? How about some Millers/octane booster or Redex on the next fill?
Roy748
Post by Roy748 » Mon Apr 15, 2019 5:07 pm
Hello.
Plugs I believe are ok as runs very smooth with a good tick over. I believe it's most prevalent after using supermarket fuel, and having read a few threads on here it would seem it's a common problem.
ognob
Post by ognob » Mon Apr 15, 2019 5:11 pm
I’d try the other fuel or additives as suggested
Worth it for science
Roy748
Post by Roy748 » Mon Apr 15, 2019 5:19 pm
Thanks, will do.
teenmal
Post by teenmal » Mon Apr 15, 2019 6:28 pm
Ha ha, pinking, some of my old customers used to call it jingle bells. (Pre ignition).
Take care.
TheLongRoad
Post by TheLongRoad » Mon Apr 15, 2019 6:59 pm
Run mine on the cheap supermarket stuff and it doesn’t ‘pink’. I love that term, to pink, my Dad used it a lot as his Ford Anglia did it all the time :D
2002 Friendee 2.0 ltr Petrol.
Bonneville
Post by Bonneville » Tue Apr 16, 2019 7:31 am
Check your ignition timing. It's in the service book but in Japanese so I can't tell at what mileage. Unlike modern cars, no knock sensor or stick coils on Bongo so there is no way to compensate for wear or fuel quality. I suspect it's never checked over here hence folk having issues as they get older. Mine was a degree out. Needs to be 6 degrees BTDC.
Flanners
Post by Flanners » Tue Apr 16, 2019 7:49 am
This post from 2010
viewtopic.php?t=40079
Roy748
Post by Roy748 » Tue Apr 16, 2019 11:20 pm
Thanks for all the helpful advice, definitely some good pointers to consider.
BongoBongo123
Post by BongoBongo123 » Wed Apr 17, 2019 6:55 pm
Regarding supermarket petrol. The one time I put it in a petrol car did nothing to persuade me me that the reports
of cars not running well on it were untrue. I had Millers Eco Max in there as well so it probably would have ran like
a bag of spanners if I did not have that in. It seemed to lack poke and refinement compared to standard BP which I normally
put in.
I was under the impression that pinking (like a ticking/rattle-y noise) when accelerating was a symptom of timing or fuel mixture running lean.
Worth doing the easy bits first, maybe change your air filter (which will do no harm in itself).
