Bongo Petrol V6 - Fuel injection?
Gripped
Post by Gripped » Fri Mar 29, 2019 12:06 am
Assuming the V6 Bongo has fuel injection (the J5 engine does have a dizzy and HT leads after all) do you know the easiest way to disconnect the injectors?
I want to do some compression tests while the spark plugs are out, so need to stop petrol squirting in while I turn the engine over.
Much obliged !
Re: Bongo Petrol V6 - Fuel injection?
Post by teenmal » Fri Mar 29, 2019 2:38 am
Just remove the Injector / fuel pump relay and or fuses.
