I have what I was told is a pair of rear Bongo springs. However it would be very useful if I could get confirmation
of the correct dimensions of Bongo rear springs.
Narrow end diameter = 105mm
Wide end diameter = 136mm
Height uncompressed =375mm
I guess the ideal is if a supplier of such items has a pair in stock they can wave a tape measure over.
Or of course if you have a set hanging around that came off your Bongo that would also be perfect.
Much obliged in advance !
Rear springs dimensions
- BongoBongo123
Re: Rear springs dimensions
Narrow end diameter = 107.50 mm
Wide end diameter = 138 mm
Height uncompressed =369 mm
Weight 4.7 KG
Weight 4.7 KG
- BongoBongo123
Great that looks pretty close. Thanks Teenmal.
