High pressure oil feed pipe to turbo
- Apprentice Bongonaut
Hi - I need to replace a leaking oil pipe from the top of the turbo (the high pressure feed pipe). I’ve sourced a second hand one from Bongospares but before I change the pipe I wondered if anyone knew the torque settings for the banjo bolts at either end?
2003 AFT 2.5 heavy oil burner
Re: High pressure oil feed pipe to turbo
11.8-17.8 Nm.
