Door Step
Door Step
A simple question...how do you remove the plastic step inside the drivers and passengers doors....asked on the Facebook group and was totally ignored !!!
- Jillygumbo
Re: Door Step
Unfortunately, you've asked this question the day the majority of the genned up people are travelling to the Big Bash in Stourport. Please be patient - someone will come along with an answer soon. I do know it's not a hard thing to do!
Jillygumbo, Tonto & Ruca
- g8dhe
Re: Door Step
They just clip in see the mechanical diagrams http://lushprojects.com/bongopartsmk2/c ... o=.html#14
Re: Door Step
Cheers Bob....Been in stealth mode for a year or so..Just watching and learning
Re: Door Step
Is Geoff's info what you need, or do you mean the plastic step bit inside the front doors?
Not that I know how you would remove those, haven't looked at it.
Goeff's info relates to the most common step question we get.
Re: Door Step
If it's the plastic step itself, you lift the seats. There are 2 push-in clips at the top of the plastic cover, where the seat sits. You hold the middle of the clips, pull them and pop them out, and pull the step away.
Allan's closed. in Plymouth we recommend PGS (Plymouth Garage Services) or Mayflower Auto Services
Re: Door Step
First time back on for a while...Thanks for the replies,It's the side door step I want off..
