Under Engine Cover - Bolt Size ??
- Bluespanner
Having removed the under engine cover to do maintenance I've mislaid the bolts that secure it to the vehicle. Tried AVA they don't stock them and getting them from Mazda will cost a arm & leg. Anyone know the bolt size/spec for the engine cover.. Cheers in advance
Re: Under Engine Cover - Bolt Size ??
I’ve not removed the undercover from the engine on the Bongo yet, but most of my other vehicles have used a plastic rivit that are cheap on Amazon. Plus they are reusable. Maybe they’d work for you. Otherwise it’s Bongo breakers for some used ones
2002 Friendee 2.0 ltr Petrol.
They're 6mm threads with 10mm heads.
Allan's closed. in Plymouth we recommend PGS (Plymouth Garage Services) or Mayflower Auto Services
- Bluespanner
Thanks Doone, I shall attempt to source some with a flange on the head and report back
Go to ebay and search for "M6 flanged stainless"
You will get loads of vendors, I've used this lot before:-
https://www.ebay.co.uk/itm/M6-6mm-A2-ST ... urNv4ZFTaw
Luckily, I've just taken mine off so I measured one and it's 15mm long. Closest size on there is 16mm which will work fine.
The ones on the V6 are a bit longer than the diesels, I'm guessing its about about 1".
