Symptoms, with the engine warmed up to normal operating temperature:
- The gearbox changes normally from 1st - 2nd - 3rd gear.
- Regardless of road or engine speed, the gearbox will not change up to 4th gear.
- The torque converter lockup is not working (the revs vary with throttle position when in 3rd).
- Due to the torque converter being unlocked and only being in 3rd gear, I’m doing > 3k RPM at 60 mph.
- The HOLD light is *not* flashing at all.
- The HOLD light is not on continually (I don’t have the button on the gear lever pressed in )
- I have tried to read the diagnostic codes but unsurprisingly (as the hold light is not flashing) there are none.
- I’ve inspected and cleaned the contacts of all the connectors connected to the gearbox.
- I've tried disconnecting the engine speed and road speed sensors to make sure I do get fault codes when these are not connected.
- I have checked the electrical resistance of the solenoids, they are all within spec.
- I have removed the valve body and tested the solenoids with an airline at 60psi, then applying 12v, they all appear to be working correctly (as well as can be determined by such a crude test).
- After rinsing the filter as well as I can (I don’t have a spare to hand and it looked ok), reassembling and filling with new fluid, the symptoms are unchanged.
- The engine temperature sensor appears to be giving a reasonable voltage reading at the ECU pin [2N]. 2.25V when cold and 0.6V when hot.
- The road speed sensor appears to be giving a reasonable signal at the ECU pin [2G].
- The gear changes, such as they are, feel very precise and are nice and smooth.
I have also looked at the signals on the solenoid output pins of the ECU [1E, 1F, 1H, 1J, 1I], the results are interesting and might point to an issue somewhere. The shift A and shift B solenoid outputs appear to be correct and correspond sensibly to the states of the first 3 gears.
Link to ECU pin connections (google drive)
I’m not sure what the “all running clutch” (translated from the wiring diagram using google translate) solenoid is supposed to do [1J] but it does seem to switch cleanly when you put the car in gear (or was that when you start moving I can’t remember now I come to write the post - anyway it looked kind of sensible).
The lock-up clutch solenoid output pin [1I] is doing something that seems to me to be very strange indeed, as soon as the ignition is switched on it outputs a pulse at 51Hz, this doesn’t change in frequency or duty while driving [channel B in the scope image linked below]. This doesn’t look right to me?
Link to lock-up solenoid signal scope image (google drive)
The line pressure solenoid pin [1E] is also doing something that seems strange to me, it’s got the same 51Hz output that remains unchanged under different driving conditions, apart from the fact the signal only appears once the engine is doing more than roughly 1700 RPM [channel A in image linked below, seen to start pulsing as the revs increase]. This doesn’t look right to me either?
Link to line pressure solenoid signal scope image (google drive)
I should add that the scope probes were set to 10x, in case anyone looks at the voltage levels and thinks they are a little low.
Has anybody else seen this sort of thing or have any other ideas. I suspect an issue with the ECU, what do you guys think? I probably need to speak to a specialist, any recommendations? Reading previous posts it looks like I want to get in touch with Alacritys (George)?
Many many thanks in advance for any help anyone can provide.
