Transmission Control Unit or ECU
Hi All,
Can anyone advise me on where, or how, to locate the above unit within the vehicle. I have been trying to source a new part and have been told I require the part number to do so.
The vehicle is a 2000 petrol 2.0l automatic
Re: Transmission Control Unit or ECU
Here you go 18-880A FF2218881A
18880A
MODULE,POWERTRAIN CONTROL
A (FF22-18-
http://lushprojects.com/bongopartsmk2/c ... o=.html#13
Take care
I hope you've got deep pockets! These ECUs cost around £1100 plus postage plus VAT.
- g8dhe
Might be worth having a word with George at BongoSpares, he used to have a load of recovered units.
Has it been confirmed that the TCM is the actual problem ? Not many TCM/PCM get reported as being faulty as such.
Echo that, what is the problem which necessitates replacement?
Thanks for all replies. Sounds costly but will contact George, describe symptoms and hope for some simple fix.
Worth letting us know symptoms, we have some top techie peeps here.
Have had some helpful replies already. The garage strongly suspect it is the ECU/TCU. It gets to the top of revs range, seems to be restricted and then changes with a bang. All fault codes were cleared, it ran for 3 hours and now no power and struggles before clearing again. Very difficult to describe but sounds terminal!
- Alacrity
- Tribal Elder
Sounds like poor engine performance to me. What were the codes & were they gearbox or engine codes?
Garage cleared codes but cannot remember what they were. Definitely gear box.
Really could do with a Bongo friendly garage in Birmingham if you know of one.
- Alacrity
- Tribal Elder
Why definitely gearbox?
Good luck, I shall offer no more advice on this.
? Extraordinary - use a different, professional, garage in future.Garage cleared codes but cannot remember what they were
As I say, classic engine issue.It gets to the top of revs range, seems to be restricted and then changes with a bang. All fault codes were cleared, it ran for 3 hours and now no power and struggles before clearing again
- Muzorewa
Woody - check out Alacrity's sig, he knows what's what on auto boxes
"Sounds like poor engine performance to me. What were the codes & were they gearbox or engine codes?"
When he says gearbox I think he might be referring to gearbox "Codes" . I would hope so.??
Take care.
Take care.
Thanks for all your replies. Have done some research and think I have found a Bongo friendly garage near to us. Here's hoping.
