Hello everyone,
I am new to the bongo world and enjoying every minute. Yesterday my bongo had a little accident and wet itself. Dumping all coolant in a matter of minutes. After reading forum looks like a corroded pipe issue. As a useless mechanic can anybody recommend assistance in the South Tyneside, Newcastle or Sunderland area. Obviously not able to move and could do with a home visit.
Many thanks for any advice
Dumped coolant South Shields
Re: Dumped coolant South Shields
Hi, and welcome,to BF.
Sorry to hear of your problem, naughty Bongy.
If you have the V6 or diesel the system must be bled properly once the pipe is replaced, the 2 ltr petrol is much simpler.
I don't know your part of the world so well, but hopefully someone will recommend a local Bongo expert.
Bleed videos here:
https://m.youtube.com/watch?v=jRAKOSxgbKo
Bleed videos here:
do a search for a member on here called stuc (stuart hes very active in your area,) maybe get him on facespace or sumat.
here he is. memberlist.php?mode=viewprofile&u=8582
This firm is recommended: https://igmaynard.co.uk/places/united-k ... gh-motors/
As Ian says Tony at Derwenthaugh can help or Tim Wing at the Bongo Barn in Stocksfield is very knowledgeable on all things bongo.
Sorry for slow reply but I'm not on much these days. I need to address that.
Stu
Stu
i would go into hiding if i had a bright green bongo too.
HI. I have just had a similar problem with coolant. Luckily the AA came to my rescue and recovered it from home to the bongo experienced garage. I wasn't sure they would do this but if you have breakdown cover you may just be able to do the same.
