Ahhhhhhhhhh!
Done the head for a third time and on the finishing straight i managed to snap the diesel return loop off one of the end injectors. Is there anyway to reattach it.
Quite soft metal, will it solde, braise or can i tap it and seal with JD weld or am i going to have to buy another.
If so anyone know wjere i can get one £85 on ebay
cheers
fuel return loop
- Bongonaut
Re: fuel return loop
THREE cracked heads? How on earth did you manage that
dont think hes said that mike.
According to Nothern Bongolow ,you need to be carefully what leak off pipe assy you order .
Quote...
"careful,
there are 2 types, one for long glow plugs, one for short glow plugs. the difference is the low plugs and connecting bar sit lower and will touch the top of a high loop pipe."
Quote...
"careful,
I'm sure he hasn't but just trying to understand the 'done' in
Yrs, Confused and AgeingDone the head for a third time
- Bongonaut
had to buy one £35 quid so not to bad, fuel pump leaking now
"£85 on ebay"???? for next - https://www.ebay.co.uk/p/Genuine-Ford-O ... 1609798705 Alu-ring I used kia/hyundai Porter, Galloper, Pregio
it is "china" loop - cost $12 (in Russia) https://ru.aliexpress.com/store/product ... Title=true
