Hi All
I need to replace my driver side sill but I notice that it is part of the side panel can anyone suggest how I replace this sill please also are the front wing panels bolt on, I would be grateful for any advice .
Steve
bongo sills
Re: bongo sills
Yes the front wings are of the bolt on type and the sills are cut and weld/bond type.
https://www.ebay.co.uk/sch/i.html?_from ... s&_sacat=0
take Care..
take Care..
Re: bongo sills
With regard to the plastic sill trim on my 2002 it has dislodged from the fittings at the rear wheel end, can anyone tell me how to fix it back on?? Looks like the female part on the plastic trim has an opening to allow this to be pushed front to rear along the length rather than just pushing against it to force it back on, any ideas?
Re: bongo sills
No it is the plastic body coloured strip between the wheels shown in bold black on your diagram.
Re: bongo sills
Sounds like your vehicle is fitted with sidesteps/ body mouldings , if you look at the diagram you will see a list of fixings/fasteners.
https://translate.google.co.uk/translat ... rev=search
Take care.
Take care.
