Removing the side door panel?
Hi.
I want to take off the door card of the side door to fit insulation. Does anyone know how I get the inside door handle off?
Does it just pry off?
Thanks!
Thanks!
Black Aero City Runner 2L petrol with full side conversion
Re: Removing the side door panel?
lean on the panel around the handle and look behind, its a horse shoe clip, get a thin screwdriver and hook it off then full the handle off the splines.
Great! Thank you
That reminds me, I've been intending to ask how to remove the side door 'L shaped' window surround since I noticed it flapping around during the summer hols. Should it be held on several spring clips? At least two have fallen out of that area since I've had the van
It's not shown on the same parts book diagram.
Mark
- g8dhe
Yes and some very odd shaped square ones as well on the ones below the window!
http://bit.ly/2jCMXHV
http://bit.ly/2jDA9RK
on the L shaped panel there is a spacer type stand off piece as well as the clips, this is the bit the bit that will have broken off, so now clips wont ness fix it im afraid.
Is the spacer part of the original L panel molding or separate? I'm sure if it's just a spacer that's needed I can fabricate something and bond it to the L panel using an epoxy adhesive.Northern Bongolow wrote:on the L shaped panel there is a spacer type stand off piece as well as the clips, this is the bit the bit that will have broken off, so now clips wont ness fix it im afraid.
Thank you all for your help & advice
Mark
its part of the panel, i did what you are suggesting on mine for a year or 2 until the squeaking repair finally drove me mad so i replaced it. .
No squeaks from that area at the moment so perhaps I'd be best to leave it well alone. Or perhaps I can't hear it over the cups, pans and cutlery rattling aroundNorthern Bongolow wrote:its part of the panel, i did what you are suggesting on mine for a year or 2 until the squeaking repair finally drove me mad so i replaced it. .
Mark
