newbie Bongo owner with ticking noise question...
mr_marrakesh
Re: newbie Bongo owner with ticking noise question...
Post by mr_marrakesh » Mon Feb 13, 2017 10:33 pm
Hi there, I'm pretty sure from the description that I have the same problem with my V6. So my question is, how much is a charcoal canister solenoid and also, if I just ignore this ticking noise is it going to cause me problems down the line?
2001 V6 LPG AFT full side conversion
Bongolia
Post by Bongolia » Tue Feb 14, 2017 12:52 am
mr_marrakesh wrote:Hi there, I'm pretty sure from the description that I have the same problem with my V6. So my question is, how much is a charcoal canister solenoid and also, if I just ignore this ticking noise is it going to cause me problems down the line?
This device is part of the emissions control system.
A charcoal canister is there to catch the fuel vapours from the tank normally.
When the ECU sees a run signal it releases the gas by opening the canister allowing air to pass through the canister and so the charcoal taking the mixture into the engine where it is burnt.
Whether it could be safely left I am not sure, I would think not, as if the valve is being opened when it shouldn't then it may adversely affect the fuel air ratio and that could lead to problems.
Having said that the O2 sensor may try and correct that situation.
I would say its best to repair/replace it.
Gasy
Post by Gasy » Wed Feb 15, 2017 8:46 pm
As has been said
Thanks for posting your results
It's good for info to be shared with all
NOT locked away where only members can see it
Especially as most of it has been given by people on here
That's how we will keep these old bongos on the road by sharing the info we learn
Enzoforever
Post by Enzoforever » Sun Oct 22, 2017 6:55 pm
Hi, sorry for the hijack of thread, I have tried to contact silverbongo directly to no avail. I was wondering does anyone know how much the charcoal canister is, if it is actually available to buy and if it isn't does anyone know of a replacement alternative ?
Post by teenmal » Sun Oct 22, 2017 8:15 pm
Enzoforever wrote: Sun Oct 22, 2017 6:55 pm Hi, sorry for the hijack of thread, I have tried to contact silverbongo directly to no avail. I was wondering does anyone know how much the charcoal canister is, if it is actually available to buy and if it isn't does anyone know of a replacement alternative ?
It would appear they did not replace the canister but they replaced the
“charcoal canister solenoid
Enzoforever
Post by Enzoforever » Sun Oct 22, 2017 8:55 pm
Sorry yeah, the charcoal canister solenoid.
Same applies, any idea if it is available and if so how much. Cheers
Post by teenmal » Mon Oct 23, 2017 11:42 am
Enzoforever wrote: Sun Oct 22, 2017 8:55 pm Sorry yeah, the charcoal canister solenoid.
Can be purchased from Mazda Dealer £70~£100 depending on where you go, the old trick was to wrap them in foam.
Enzoforever
Post by Enzoforever » Tue Oct 24, 2017 9:02 am
I presume the wrapping in foam solves the clicking noise but surely something is wrong with it. Do you think it's important to get it changed?
Post by mikeonb4c » Tue Oct 24, 2017 10:28 am
Enzoforever wrote: Tue Oct 24, 2017 9:02 am I presume the wrapping in foam solves the clicking noise but surely something is wrong with it. Do you think it's important to get it changed?
Unless you're a dodgy dealer wanting to shift it ;-)
Post by teenmal » Tue Oct 24, 2017 1:27 pm
Personally (if it is the problem) I would fit a New solenoid not S/H , as I said "old trick was to wrap them in foam"
