Hello all
Bought a Bongo Auto Top, March 2014 2.5D Automatic 2000 reg.
Wife and grandchildren love it.
Not converted, used several times last year locally in Wales and across the water to England, with a grand tour of the French Alps in August 2014 - no problem, dream to drive.
This year we were in Cardigan in June and problems.
Flashing Coil light and Hold light and dropping into safe mode every few minutes. Called Green Flag Good for recovery, poor on diagnostics.
Lots of reading web pages and forum entries. Struggling to find a local repair shop wanting to look at my problem. Most said it must be gearbox and its an automatic - no thanks.
Found a great mechanic two miles from home.
Diagnostic readings of P0510 seem to be the problem. We changed the Throttle Sensor (CB0541aoc 42-Aco) and the Throttle Switch (BH4C66470 18-660E) (long story about sourcing these)
The Mechanic fitted the parts and tested the Bongo Hold light clear and also the Flashing Coil light. No safe mode on many test runs over last week - no problem.
However, the Flashing Coil light returned without any safe mode and after clearing the fault reading on the diagnostic reader, re-read the system and P0510 has returned.
Sorry about the long saga
Any help would be great as Nigel the mechanic's hair is turning White.
Many thanks
Willumm the Wheels
PS. Most important Is It Safe to Drive
Flashing Coil Light and Hold light.
Re: Flashing Coil Light and Hold light.
Flashing hold light and glow plug light usually means alternator problem.
- g8dhe
Ah no, alternator is steady Charge and Sediment!
Flashing of glowplug means ECU reporting fault and Hold means TCM reporting fault.
Many thanks
I just hope this information will help the Mechanic's
Greying hair problem.
Many thanks
Willumm the Wheels
Many thanks
Willumm the Wheels
Thanks for the reading material
Will read these over a cup of real Tea no bagsssssssssss aloud
Supreme Being I thank you again
Willumm the Wheels
Willumm the Wheels
Hold light.Engine cutting out
Just had lack of power to gearbox then eventually engine cutout..on M25 racecoarse! Had hold light flash on but generally it's starts again then few miles from happens again..help!
- g8dhe
This needs to be a new thread ...
Flashing Hold light means the computer is reporting a problem, the flashing stops when the problem is resolved so it sounds like you have an intermittent problem. You need to read the diagnostic socket error code when the light is flashing to help pinpoint the fault.
