Electric window switches the wrong way round!
Ricey
Post by Ricey » Sun Jun 22, 2014 12:30 pm
Hi guys,
an odd issue! The window switches on the drivers door are wired up the wrong way round!!
I've had a quick search and couldn't see anything, so...
The switches on the drivers door control the opposite windows - the left (innermost) one controls the driver's side and the outer one does the passenger side. As a knock on the 'Auto' function works on the passenger side!
What is the best/easiest way to swap them over? Not sure how or when it was done this way, but it's a fresh import so I can only guess - in Japan???
thanks all
321Away
Re: Electric window switches the wrong way round!
Post by 321Away » Sat Jun 28, 2014 11:23 am
Its because an early switch is fitted to a later model or round the other way, late switch early model. easily rectified, pull switch and chop the wiring about
julian
Post by Simon Jones » Sat Jun 28, 2014 3:25 pm
