What is this wire.
kingbillybongo
What is this wire.
Post by kingbillybongo » Sun Oct 06, 2013 9:54 am
Dangling in the middle behind grill,wondered if it's a feed for fogs or spots but no power to it,unless a fuse has been left out until needed?
Can any one help identify this wire?thanks. :roll:
[color=#0000BF]billybongofreedom[/color]
Re: What is this wire.
Post by g8dhe » Sun Oct 06, 2013 11:35 am
There are several wires behind the grill, some are for testing, some are spots (other items not fitted fuse/relay/switch etc).
Image Spherical Visions
kingbillybongo
Post by kingbillybongo » Sun Oct 06, 2013 12:00 pm
It had a plug and blanking plug on a 2wire cable clipped behind the front grill?
Post by g8dhe » Sun Oct 06, 2013 6:29 pm
What colours are the wires ? Violet and Black are the Front Fog lights.
and located here E2-03 & E2-04
Or it maybe ABS test sockets on 1/2 sockets with Black, White/red & Green/Black as the colours O-09;
Simon Jones
Post by Simon Jones » Sun Oct 06, 2013 8:57 pm
If it's on the central vertical brace behind the grille, then it's a temperature sensor for the air con.
kingbillybongo
Post by kingbillybongo » Mon Oct 07, 2013 12:52 pm
the wires appear to be red and a yellow and black?
Post by g8dhe » Mon Oct 07, 2013 2:49 pm
Humm, what year and type of controls do you have;
The front air temp. sensor G3-12 is Red/Green and Yellow/Black, maybe your missing seeing the green trace on the red, actually I see now that you say it has a blanking plug - I think you might find the "blank" is the sensor itself!
kingbillybongo
Post by kingbillybongo » Mon Oct 07, 2013 6:26 pm
g8dhe wrote:Humm, what year and type of controls do you have;
Thanks very much for your help,your right ,I think it is the sensor so need to get it sorted as it seems to have started to fall to bits,trip back to andy again Saturday .cheers :roll:
