Cutting out whilst driving
technophobe
Post by technophobe » Sat Aug 10, 2013 9:38 am
Driving along at 60 when the engine just cut out. Started again on third attempt. This happened 9 times with shorter intervals. Any ideas what is causing this?
Richard & Jo
Re: Cutting out whilst driving
Post by Simon Jones » Sat Aug 10, 2013 9:42 am
It could be the fuel cut off solenoid on the injector pump. May be faulty or loose connection.
Post by teenmal » Sat Aug 10, 2013 10:49 am
It would also be worthwhile checking the fuel filler cap, does the ignition light etc come on when the engine cuts out ?,if they dont it would be worthwhile investigating the ignition switch/system.
Good Luck.
Vogie
Post by Vogie » Sun Aug 11, 2013 11:42 am
Fuel filler cap? Do you mean if broken or not on properly? Lights do come on so ignition all good. Looked into solenoid. Will attempt 3 hour trek back to st Malo on wed.
Thanks techno phobe.... Got our log on activated.
Post by teenmal » Sun Aug 11, 2013 11:57 am
The fuel filler cap has a valve fitted to it, if the valve is blocked or stuck it will stop air entering the tank and cause a vacuum, clean and check the valve, or run with the cap slack (just to test it). #
Good Luck...
PS I see that the original post was from ...technophobe ..for log in problems, what vehicle do YOU have. :D
Vogie
Post by Vogie » Mon Aug 12, 2013 1:01 pm
Hi.
Same as techno phobe but 1996. Rear conversion, not sure it is the best set up though. :D
Post by Simon Jones » Mon Aug 12, 2013 1:04 pm
Vogie wrote:Hi.
Eh? How did we get from cutting out whilst driving to rear conversions :shock:
