Hi am losing coolant when i take the bongo on a good run. i did a 4 hour drive and have had to top with about a litre!
Have had the garage do a pressure test and all was fine. I have looked everywhere for a leak with no joy!
My next thing is to change the radiator and header tank caps if this does not work not sure what to do next!
Any ideas?
coolant loss
Re: coolant loss
might only leak when the stat opens, go for a run and get it open and park on some cardboard see where the drips come from, mine was easy to spot it was jetting out lik ea water pistol, and the rad leaked when i went over 2.5k revs from between the plastic bit and metal bit, so take off the air ducting and have a good look for any signs
Re: coolant loss
Thanks for the tips
I have a uv dye in there as well. I have taken it for a run, the lower rad hose was hot so thermostat is open and still cant see any leaks anywhere!
Re: coolant loss
Mine had a tiny pin hole in the hose that runs from the drivers side of the engine to feed the rear heater it only weeped when the engine was up to temp and the heatfrom the engine was evaporating most of it off, worth getting er up to temp lifting the drivers seat and taking a look.
Re: coolant loss
if it passed a pressure test then it may be the water pump. these usually leak when running, pressure only doesnt usually allow them to leak, its the combination of rotation and pressure. get a dentist angle head mirror and look for a coolant trail down the casting coming from the telltale hole at the 6 oclock position on the pump.
