Fuel sender unit
RobEvans
Fuel sender unit
Post by RobEvans » Sat Feb 02, 2013 2:06 pm
If I could have so experience and comments please.
Going to put viynal flooring in van is it worth replacing the sender unit or just doing the earth mod. I have a 1996 2.5 diesel . Have had no issues with it. Thanks for your help. Rob
helen&tony
Re: Fuel sender unit
Post by helen&tony » Sat Feb 02, 2013 2:38 pm
I replaced mine some years back, and what I'd say is cut a hatch in the vinyl, and seal it down neatly with matching coloured silicon...It looks OK if you mask it off when siliconing...I've done that on the bath at home with a plumbing inspection hatch in a tiled bathroom....you can't see it!
321Away
Post by 321Away » Sat Feb 02, 2013 2:58 pm
when the usual earth fault occurs, even if you have a brand new sender it will still register as faulty! In my experience ive only ever seen 1 faulty sender and hundreds of earth faults, ground the tank and chances are you'll never have a problem
Julian
mentaliss
Post by mentaliss » Sat Feb 02, 2013 6:52 pm
Mulletman wrote:If I could have so experience and comments please.
Because of the inaccuracy and poor quality of the sender unit match to the like wise dash unit I thought, wrongly, by purchasing a new sender unit and installing it (plus all the earthing mods) it would resolve the issue of such, I did this before I laid the new flooring, I didn't cut out the hatch area for three reasons, more work, original unit been in the vehicle over ten years, plus you would still be able to get to the sender unit by releasing the fuel tank..... 8)
jaylee
Post by jaylee » Sat Feb 02, 2013 9:42 pm
Maybe worth replacing the fuel line before doing the floor though....? Check this out & scroll down.... http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=33920
Did mine on my 95 plate a while back....
kentait
Post by kentait » Sun Feb 03, 2013 12:15 pm
earthing the fuel tank near the rear offside wheel worked for me, cheap too.
ken
winchman
Post by winchman » Mon Feb 04, 2013 7:44 am
I would replace the short fuel lines that connect the sender to the fuel system, mine had just started to perish. Other than that I wouldnt worry
I have a working spare sender if any one needs one?
RobEvans
Post by RobEvans » Mon Feb 04, 2013 5:52 pm
Thanks for all your replies. My plan is do the earth mod, replace the short fuel lines and leave a hatch in the floor thanks to everyone cheers rob
