Belt Tensioner Bolt
Belt Tensioner Bolt
Was on my way home (Norfolk) from a trip to Oban in September. Spent the night short of Scotch Corner. Shortly after setting off that morning it was all stop. Called out the RAC who diagnosed a loss of compression which they could not repair. They proceeded to relay me and my Bongo all the way down South where the Bongo was delivered to where I had bought it several years ago.
The mechanic found the belt tensioner bolt had sheared, resulting in damage to valves. I was told it could of been worse (i.e. pistons). Anyway it is all sorted now and as you can imagine it wasn't cheap, despite efforts made to keep the cost down.
My understanding is that there is little I could have done to prevent this happening, just bad luck. However there may be some of you out there who see this differently, if so I would be interested in hear from you. Bare in mind my mechanical ability is limited to checking oil, tire pressure etc.
Anyway I am real happy to have my Bongo back and that the breakdown occurred at the end of the camping season and not the start.
Mike...
PS Thanks to the people at Little Movers for being so helpful and sorting me out.
Mike...
Re: Belt Tensioner Bolt
Sounds like just plain bad luck I am afraid.
Thats a serious bolt to shear!!
Julian
Julian
g8dhe wrote:See this thread http://www.igmaynard.co.uk/bongo/forum/ ... 60#p566260
Hi Geoff,I think its the Timing Belt tension bolt.
Cheers.
- g8dhe
Yup your right, I just remembered seeing an item about Belt tensioners breaking hence the link
its an odd bolt to shear as its not exactly a load bearing bolt, it locks the tensioner into its pre-set tensioned position
julian
julian
I worked at Vauxhall garages for a while. Changing the camshaft pulley bolt was a must if the pulley removed on some engines, never the tensioners though.
As Julian as said, not a load bearing bolt. Not like there is the room around that area to get a long enough lever to overtighten either.
As I said earlier just bad luck, get a bolt that eventually failed.
bm849 - Did you actually see this sheared bolt? Just seems a very odd bolt to fail.
Sorry for not getting back to you earlier, I was travelling for work all week.
I didn't see the the sheared bolt, it could of been interesting.
Anyway, like everybody has said to me, it was just bad luck. Lets hope I am in for some good luck now and many good years to come in the Bongo.
