code 22?
bennett
code 22?
Post by bennett » Fri Jan 04, 2013 4:12 pm
Can anyone tell me what code 22 is on the engine diagnostics.
Re: code 22?
Post by francophile1947 » Fri Jan 04, 2013 5:50 pm
What engine?
Re: code 22?
Post by Simon Jones » Fri Jan 04, 2013 6:30 pm
If you're doing it the conventional way, then 22 is not listed. This is the only website I've come across that explains the diagnostic codes: http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
In addtion to what engine type you have, it would be helpful if you tell us what the symptoms are ;). The engines fitted to Bongos are a pretty ancient design, so won't have modern OBDII fault codes.
bennett
Re: code 22?
Post by bennett » Sat Jan 05, 2013 4:01 pm
Simon Jones wrote:If you're doing it the conventional way, then 22 is not listed. This is the only website I've come across that explains the diagnostic codes: http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
Engine turns over - will not start - no power getting to stop solonoid. Glow plug relay flashes indicating engine fault, garage says fault 22?
Engine 2.5 turbo diesel, 2001 flybywire
bennett
Re: code 22?
Post by bennett » Sat Jan 05, 2013 4:02 pm
francophile1947 wrote:What engine?
Re: code 22?
Post by Simon Jones » Sat Jan 05, 2013 4:59 pm
Do you know how they've concluded it's code 22? There's some more diagnostic info here, but again 22 isn't listed: http://www.igmaynard.co.uk/bongo/member ... ostics.pdf
bennett
Re: code 22?
Post by bennett » Sat Jan 05, 2013 5:17 pm
Simon Jones wrote:Do you know how they've concluded it's code 22? There's some more diagnostic info here, but again 22 isn't listed: http://www.igmaynard.co.uk/bongo/member ... ostics.pdf
Thanks really appreciate info - will speak garage again on Monday.
Cheers Neil
321Away
Re: code 22?
Post by 321Away » Mon Jan 07, 2013 1:33 pm
Does the glow plug light flash as soon as the ignition is turned on? check the internal fusebox, centre row far left? 15A.
Does the car have an alarm or immobiliser fitted?
Julian
