Leaking Diesel from the bottom of the pump looks like a leaking tap with a constant drip drip similar to you household tap when washer has worn. Read that a common fault is the O Ring seal.
Is that a pump off job or can these be replaced in place are there any other likely causes?
have not posted for sometime as the old girl has not been playing up any advice appreciated
Diesel Pump leak
Re: Diesel Pump leak
depends on the leak, there are 3 seals that fail in the pump, 2 on the sides (inside is awkward) and rear, if its side seals they can be done in situ, if its the rear, its best to get it out, even then its a mare of a job.
julian
julian
- Driver+Passengers
If you're a member of the club, there is a good factsheet on this...
http://www.igmaynard.co.uk/bongo/member ... elpump.pdf
It says you need small hands.
Thank you Julian ,have a fear its the latter, picked up a set of O ring seals from the club shop!321Away wrote:depends on the leak, there are 3 seals that fail in the pump, 2 on the sides (inside is awkward) and rear, if its side seals they can be done in situ, if its the rear, its best to get it out, even then its a mare of a job.
julian
Thanks !
very usfull link
I recently had leaks from all fuel pump seals......I sourced a pump from this forum [Simon Jones ] overhauled it at a local Bosch Dealer. works a treat now....on veg too.
- Simon Jones
Free seals up for grabs here: http://www.igmaynard.co.uk/bongo/forum/ ... =5&t=58713
