sediment/charge light again!!
chiefster1976
Post by chiefster1976 » Mon Sep 10, 2012 10:57 am
Hi all.. Seems this is a common problem with different fixes, but do we just expect its the alternator every time??
Both lights come on are bright never dim.. Only on occasions comes on,flickers,sometimes stays on for around 10-30 seconds.
Reving sometime helps them go out but NOT always,sometimes stays on at 2500rpm..
Heres my readings thus far although i have NOT managed to catch a reading as yet when the sed/charge lights are ON.. :x
**Under load = lights/main beam/CB radio/Radio,interior lights,AC on.**
...............................not running...................Running....................Under load
Leisure batt..............12.6V.........................13.8V.....................13.8V AC kicks in 13.1V
Starter batt..............12.6V........................13.8V......................13.8V AC kicks in 13.1V
Alternator..................................................14.0V.....................13.4V.
all fuses o.k. earth to leisure and starter o.k.. Had issue sometime after a redarc split relay was fitted,but maybe just a coincedence as the charging graph above seems pretty consistant..
An auto sparky recons, to fully determin if alternator is on its way out,i need to catch both lights on and test then at the alternator..
Any ideas to throw around is appreciated..
She is up for sale but scratching my head wether to just get the alternator reconditioned?? :idea:
Racing green with extras!!Self build full side conversion which rocks!!!
alan
Re: sediment/charge light again!!
Post by alan » Mon Sep 10, 2012 11:51 am
my was doing this but got a read when the ligths where on hey the post http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=57631
take it easy drive a bongo
chiefster1976
Post by chiefster1976 » Thu Sep 20, 2012 11:07 am
Up date ALL!! Bongo under load(lights/A.C etc on) when sediment light OFF is 13.5 Volts ...
i managed to catch the voltage when the sediment light and charge light are on... = 12.6 Volts...
Does this indicate that the alternator is goosed????
Post by g8dhe » Thu Sep 20, 2012 4:32 pm
If the engine is running then you would expect the alternator to be charging the battery in excess of 12.6 volts (this is the nominal battery voltage under no load!), 14+ volts is expected when you have a few rev's going as well. The lights are driven directly from the alternator signalling circuit;
If you click the red 3 link then you will see it feeds the two lamps charge/sediment (via diodes) directly.
Image Spherical Visions
chiefster1976
Post by chiefster1976 » Tue Sep 25, 2012 9:09 am
Update... Alterenator is off the car. A work collegue (suto sparky) said brushes are o.k, good be just a bad earth originally, but sugests to chang ethe Regulator to be safe. my local electrical suppliers cannot find a listing for japanese hitachi LR190-731 regulators..
:evil: :evil:
Most of the ranger/ B2500 alternators seem to be only 70-80amp on www.ebay.com.au..(OZ)
My alternator was an exchange unit replaced in January 2010...
Anyone found a supplier of Hitachi LR190-731 regualtors etc??
Post by Northern Bongolow » Tue Sep 25, 2012 8:01 pm
there was some guy who was rebuilding the bongo alternator from the cornwall area i think, he may supply the parts you need to have it rebuilt local to you.
someone may be able to find a link to the thread [-o< [-o< .
Post by g8dhe » Tue Sep 25, 2012 8:41 pm
Isn't the alternator itself the LR190-731 ?
and the regulator within it is the L190 G6340 ?
See http://www.woodauto.com/Unit.aspx?Man=H ... =LR190731B
Doesn't help locate one however!
Simon Jones
Post by Simon Jones » Tue Sep 25, 2012 11:18 pm
Albaston in Cornwall rebuild / supply 100A alternators:
Albaston Starters & Alternators
Albaston Garage
Gunnislake
Cornwall PL18 9EL
01822 832925
chiefster1976
Post by chiefster1976 » Wed Sep 26, 2012 10:25 am
HOLD on, we may have a break through!! So the actual regulator codes are L190G6340?????????????? :shock: :shock:
i may need to contact again the suppliers here for another go on the rectifier then??
Last chnace senario is to buy a new alternator i guess.. #-o #-o #-o
Post by g8dhe » Wed Sep 26, 2012 10:34 am
Thats the OEM's code for the regulator, if you search for the for the first number you only get complete Alternators showing up.
Post by Northern Bongolow » Wed Sep 26, 2012 11:31 am
Simon Jones wrote:Albaston in Cornwall rebuild / supply 100A alternators:
Albaston Garage
Gunnislake
Cornwall PL18 9EL
01822 832925
thanks simon. :)
chiefster1976
Post by chiefster1976 » Mon Oct 08, 2012 4:56 am
Cheers simon ill give those guys a call!!
