filters
bm53
filters
Post by bm53 » Sun Sep 09, 2012 11:40 am
How many filters are thear on a bongo is it just the 2
Driver+Passengers
Re: filters
Post by Driver+Passengers » Sun Sep 09, 2012 12:02 pm
What model do you have?
There are the three filters to change every year or two: fuel filter, engine oil filter and air filter.
The fuel line on a diesel, at least, has a further strainer referred to as the "banjo filter" which you may need a cotton bud to extract/inspect.
The auto transmission fluid is filtered through a strainer but you have to remove the sump to get at it. There should also be strainer inserts under the caps on the brake and power steering fluid reservoirs. My van doesn't have a filter on the air supply to the blowers, but I've wondered about fitting one.
I may have missed one.
More info here, if you're a club member: http://www.igmaynard.co.uk/bongo/member ... hedule.pdf
Hope this helps.
Matt.
Image Image
