Now the proud owner of a 2lt petrol Bongo Pop Top courtesy of a Bongo Fury Member!
There may be lots of questions coming your way...first up (I tired a search but failed to find the answer)
The rear wiper appears to be on or off...anyone tried modding the electronics to make it a bit more intermittent?
Thanks?
Rear Wiper
Re: Rear Wiper
That sounds like a plan, The LR4x4 forum speaks about doing that for a landrover rear wiper, I'd be interested.
Daz
Daz
Daz and debs
Re: Rear Wiper
I might be wrong but i am sure someone had done it
Re: Rear Wiper
Cheers will take a look, guessing a simple timer circuit will do it but wondered how much current the motor might be taking.
This looks like a similar circuit: http://www.techlib.com/files/wiperkik.pdf
- g8dhe
Re: Rear Wiper
If you have all the parts in the draw then fine also you will need to switch it over from intermittent to normal so another relay as well, otherwise at £8 for a kit ...
