When selecting drive my bongo doesn't move!
I have a 4 x4 with some issues at the moment which will be resolved end of the week I hope!
However I have an unrelated question!
Every other auto I've driven moves slightly when you select drive(without any throttle) but my bongo doesn't?untill you give it throttle of course then it does,is this normal for bongo's?
Re: When selecting drive my bongo doesn't move!
I've always driven autos and thought the same as you however, the mazda autos do seem to be very smooth to engage. I don't think you have a problem.
Paul
Paul
Thanks for your reply,all a learning curve
Hmmm. Mine creeps forward in D and holds position on a slight incline.
- Dr Fingers
mikeonb4c wrote:Hmmm. Mine creeps forward in D and holds position on a slight incline.
Same here..perfect when just gently inching forward in a jam..
Derek
I would imagine that it depends on the RPM and the state of the clutch.
Cheers.
Cheers.
I wondered about this as on an slight incline it holds but too steep and it rolls back whilst in Drive, I assume this is normal, on the flat it creeps forwards slowly
Same with mine.
Daz and debs
Could it mean a problem then?
- mikeWalsall
Have you checked the fluid level and it's colour ..??
An high tick over gives more 'creep' ...
sunnyjim82 wrote:Could it mean a problem then?
You could pm Alacrity for his advice, as he's an autobox specialist, but I wouldn't worry as long ad its working ok (although I would check fluid condition and level and respond accordingly)
