rear view mirror
- nicstrike
- Tribal Elder
rear view mirror
is there a secret technique to removing the mirror from the bracket that is bonded to the windscreen. there is small slot in the bottom of the casting but i can't see what is happening in there!
- Tribal Elder
Re: rear view mirror
You need to insert a small flat bladed screwdriver in the slot and then slide the mirror upwards - the part on the windscreen has a tensioned arm that you move towards the screen with the screwdriver. Hope this helps.
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
This may also help http://www.igmaynard.co.uk/bongo/forum/ ... ove+mirror
Alison
If you wink your left eye whilst tapping your right foot whilst levering the mirror upwards... it'll make no difference whatsoever.
- nicstrike
- Tribal Elder
figured it was something like that , just couldnt suss it!kawasaki kid wrote:You need to insert a small flat bladed screwdriver in the slot and then slide the mirror upwards - the part on the windscreen has a tensioned arm that you move towards the screen with the screwdriver. Hope this helps.
cant open it alison. aparrantly i dont have permission!Alison01326 wrote:This may also help http://www.igmaynard.co.uk/bongo/forum/ ... ove+mirror
- Tribal Elder
Be gentle when doing it as windsreens are expensive when I removed mine it was because the screen was being replaced as a nice Irish truck driver used my screen as target practice.
I couldn`t open the link either.
- nicstrike
- Tribal Elder
i've picked up a replacement mirror as the one in the bongo looks like its got a big " thumbprint " on it , where damp has got between the layers. looking to swap them over.kawasaki kid wrote:Be gentle when doing it as windsreens are expensive when I removed mine it was because the screen was being replaced as a nice Irish truck driver used my screen as target practice.
Looking into that .. watch this space!nicstrike wrote:cant open it alison. aparrantly i dont have permission!
Alison
- nicstrike
- Tribal Elder
Alison01326 wrote:Looking into that .. watch this space!nicstrike wrote:cant open it alison. aparrantly i dont have permission!
i cant...the clouds are hypnotising me!!!
If the clouds should clear anytime before Summer, the link should be working nownicstrike wrote:Alison01326 wrote:Looking into that .. watch this space!nicstrike wrote:cant open it alison. aparrantly i dont have permission!
Alison
- nicstrike
- Tribal Elder
as if by magic....there it was! thanks alison.
