Hi gang...just back from two months in France
A couple of small disasters
Hose on rear aircon went followed immediately by water pump....Ford dealers in Manosque (Provence) sorted out new parts and fitted them in three days...good service.
However..several hundred miles later a high pitched hum has started when I accellerate hard....sounds a bit like a lawnmower...very intermittent and cdssapears when engine warmed up properly.
Had my local garage check the belts etc...they suspect the turbo
any comments?
thanks
H
Turbo problems?
Manifold studs nonny nonny manifold studs!!!!
Yes could be ...reading the archives....back to the garage on Friday (Working tomorrow with group..and yes using the Bongo.
Does anyone have any opinions on the drivability of the vehicle...is it safe?
I've done over 1000km since the lawnmower first started up its whining.
H
H
