Inside rear light help
Hi all just got my first Bongo only thing that dosnt work is the inside rear light it works when you put it to on but not when you put it to door and open the door! Any info on what could be wrong would be great!
Re: Inside rear light help
from memory the little on of switch is down by the lock might be a loose wire
- g8dhe
Sounds like the door switch, if its the rear Hatch then the switch is down with the locking mechanism at floor level. If you mean the sliding door then its down on the rear pillar
Sliding door part 66-820 http://www.lushprojects.com/bongopartsm ... mgno=.html
- Tribal Elder
If you are on about the sliding door light check the door switch which is located at the rear wheel end of the opening just below the mid guide rail - it could just need the contact cleaning inside - if it is the rear door the switch is in the tailgate catch and may just need a quick squirt of some cleaner on the catch. Hope this helps.
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
I had the same problem and it was a corroded fuse, might be worth checking.
Living for the weekends...
CUIDADO! VEICULO BONGO!
Its both doors so will try it all!
