Drivers window switch 'same as Mazda 323F' ????
springer
Post by springer » Thu Jul 22, 2010 9:20 am
I heard a rumour the drivers window switch on the Mazda 323F is exactly the same as the Bongo.
Is this the case, because the cheapest switch I can find for the Bongo is circa £120, but the 323F was much more common, and a UK model, so switches should be a fraction of the price.
Anyone know ? and where I could get one.
Cheers.
[-o< [-o< [-o<
liggy
Re: Drivers window switch 'same as Mazda 323F' ????
Post by liggy » Thu Jul 22, 2010 10:16 am
The rumour is correct I just got 1 off of Ebay for £20 + p&p. All you need to do is remove the outcasing but the switch is exactly the same. Type in "Mazda window switches" in the search box on ebay and you should find them but remember you need 1 from a 2 door model not a 4 door.
Simplezzzzz
jaylee
Post by jaylee » Thu Jul 22, 2010 10:27 am
This is one off a similar year 2 door 626!??
After a little modding...
jaylee
Post by jaylee » Thu Jul 22, 2010 10:32 am
In fact the rear passenger ones look exactly like the electric blind switches too!! (No modding required?) :wink:
Post by missfixit70 » Thu Jul 22, 2010 11:30 am
compatible parts list here - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=14881
Have a look on ebay or any scrapyard & be patient, one'll come along at the right price :wink:
Are you sure it's the switch that needs replacing & not the wiring between the door & body? The switches can sometimes be repaired if it is that.
springer
Post by springer » Thu Jul 22, 2010 11:34 am
The switch is definitely to blame, the electric part of it works, but the plastic switch parts have shattered, that said, having looked at the loom it looks like it needs some TLC
